주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Alienware 14 Keyboard Replacement
필요한 것
  1. Dell Alienware 14 Keyboard Replacement, Close the Display: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 2 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Remove the Screws: 2 단계, 이미지 2개 중 2개
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Keyboard Replacement, Slide and Lift the Base Cover: 3 단계, 이미지 1개 중 1개
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Keyboard Replacement, Align the Tabs: 4 단계, 이미지 1개 중 1개
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 5 단계, 이미지 1개 중 1개
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: 6 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Keyboard Replacement, Disconnecting the Battery Cable: 7 단계, 이미지 1개 중 1개
  8. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 8 단계, 이미지 1개 중 1개
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Keyboard Replacement, Using the Battery Cable: 9 단계, 이미지 1개 중 1개
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: 10 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Keyboard Replacement, The Power Button: 11 단계, 이미지 1개 중 1개
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Keyboard Replacement, Align the Tabs: 13 단계, 이미지 1개 중 1개
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: 14 단계, 이미지 1개 중 1개
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 15 단계, 이미지 1개 중 1개
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Keyboard Replacement, Connect the Battery Cable: 16 단계, 이미지 1개 중 1개
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 17 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Remove the Screws: 17 단계, 이미지 2개 중 2개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 3개 중 1개 Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 3개 중 2개 Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 3개 중 3개
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Keyboard Replacement, Lifting the Hard Drive: 19 단계, 이미지 1개 중 1개
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Keyboard Replacement, Turn the Assembly Over: 20 단계, 이미지 1개 중 1개
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Keyboard Replacement, Remove the Screw: 21 단계, 이미지 1개 중 1개
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 22 단계, 이미지 1개 중 1개
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Keyboard Replacement, Slide and Lift the Hard-Drive: 23 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Slide and Lift the Hard-Drive: 23 단계, 이미지 2개 중 2개
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Keyboard Replacement, Disconnect the Interposer: 24 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Disconnect the Interposer: 24 단계, 이미지 2개 중 2개
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Keyboard Replacement, Connect the Interposer: 25 단계, 이미지 1개 중 1개
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Keyboard Replacement, Placing the Secondary Hard-Drive: 26 단계, 이미지 1개 중 1개
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: 27 단계, 이미지 1개 중 1개
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 28 단계, 이미지 1개 중 1개
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Keyboard Replacement, Align the Screw Hole: 29 단계, 이미지 1개 중 1개
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Keyboard Replacement, Replace the Screw: 30 단계, 이미지 1개 중 1개
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Keyboard Replacement, Turn the Hard-Drive Assembly Over: 31 단계, 이미지 1개 중 1개
  31. Dell Alienware 14 Keyboard Replacement, Slide the Hard-Drive Cable: 32 단계, 이미지 1개 중 1개
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: 33 단계, 이미지 1개 중 1개
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Keyboard Replacement, Disconnecting the Status-Light Board Cable: 35 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Disconnecting the Status-Light Board Cable: 35 단계, 이미지 2개 중 2개
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  34. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 36 단계, 이미지 1개 중 1개
    • Remove the screws that secure the palm -rest assembly to the computer base.
  35. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: 37 단계, 이미지 1개 중 1개
  36. Dell Alienware 14 Keyboard Replacement, Pry the Palm-Rest Assembly: 38 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Pry the Palm-Rest Assembly: 38 단계, 이미지 2개 중 2개
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  37. Dell Alienware 14 Keyboard Replacement, Lift the Palm-Rest Assembly: 39 단계, 이미지 1개 중 1개
    • Carefully lift the palm-rest assembly and turn it over.
  38. Dell Alienware 14 Keyboard Replacement, Release the Connector Latches: 40 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Release the Connector Latches: 40 단계, 이미지 2개 중 2개
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  39. Dell Alienware 14 Keyboard Replacement, Turn the Palm-Rest Assembly: 44 단계, 이미지 1개 중 1개
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  40. Dell Alienware 14 Keyboard Replacement, Close the Display: 46 단계, 이미지 1개 중 1개
  41. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 47 단계, 이미지 1개 중 1개
    • Replace the screws that secure the palm-rest assembly to the computer base.
  42. Dell Alienware 14 Keyboard Replacement, Slide the Status-Light Board Cable: 48 단계, 이미지 1개 중 1개
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  43. Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: 49 단계, 이미지 3개 중 1개 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: 49 단계, 이미지 3개 중 2개 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: 49 단계, 이미지 3개 중 3개
    • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Lift the connector latch and disconnect the power-button board cable from the status-light board connector.
  44. Dell Alienware 14 Keyboard Replacement, Peeling the Power-Button Board Cable: 50 단계, 이미지 1개 중 1개
    • Peel the power-button board cable off the keyboard bracket.
  45. Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: 51 단계, 이미지 3개 중 1개 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: 51 단계, 이미지 3개 중 2개 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: 51 단계, 이미지 3개 중 3개
    • Lift the connector latches and disconnect the keyboard cable and keyboard-backlight cable from the keyboard-board connectors.
  46. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 52 단계, 이미지 1개 중 1개
    • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
  47. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard Bracket: 53 단계, 이미지 1개 중 1개
    • Lift the keyboard bracket at an angle and release it from the tabs on the palm-rest assembly.
  48. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: 54 단계, 이미지 1개 중 1개
    • Slide the keyboard cable and keyboard-backlight cable through the keyboard bracket.
  49. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard Bracket: 55 단계, 이미지 1개 중 1개
    • Lift the keyboard bracket off the keyboard.
  50. Dell Alienware 14 Keyboard Replacement, Remove the Screws: 56 단계, 이미지 1개 중 1개
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  51. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard: 57 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard: 57 단계, 이미지 2개 중 2개
    • Lift the keyboard and release it from the tabs on the palm-rest assembly.
  52. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard: 58 단계, 이미지 1개 중 1개
    • Slide the NEW keyboard under the tabs of the palm-rest assembly and align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
  53. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 59 단계, 이미지 1개 중 1개
    • Replace the screws that secure the keyboard to the palm-rest assembly.
  54. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: 60 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: 60 단계, 이미지 2개 중 2개
  55. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Bracket: 61 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Bracket: 61 단계, 이미지 2개 중 2개
    • Slide the keyboard bracket under the tabs on the palm-rest assembly and align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  56. Dell Alienware 14 Keyboard Replacement, Replace the Screws: 62 단계, 이미지 1개 중 1개
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  57. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: 63 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: 63 단계, 이미지 2개 중 2개
    • Slide the keyboard cable and keyboard-backlight cable into the keyboard-board connectors and press down on the connector latches to secure the cables.
  58. Dell Alienware 14 Keyboard Replacement, Routing the Power-Button Cable: 64 단계, 이미지 1개 중 1개
    • Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
  59. Dell Alienware 14 Keyboard Replacement, Sliding the Power-Button Board Cable: 65 단계, 이미지 2개 중 1개 Dell Alienware 14 Keyboard Replacement, Sliding the Power-Button Board Cable: 65 단계, 이미지 2개 중 2개
    • Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,924 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
44 회원들
안내서 1,996개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 67
전체 시간: 2,428
