주요 콘텐츠로 건너뛰기
Dell Alienware 14 Primary Hard-Drive Replacement
필요한 것
  1. Dell Alienware 14 Primary Hard-Drive Replacement, Close the Display: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 2 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 2 단계, 이미지 2/2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Primary Hard-Drive Replacement, Slide and Lift the Base Cover: 3 단계, 이미지 1/1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Tabs: 4 단계, 이미지 1/1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screws: 5 단계, 이미지 1/1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Primary Hard-Drive Replacement, Turn the Computer Over: 6 단계, 이미지 1/1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Primary Hard-Drive Replacement, Disconnecting the Battery Cable: 7 단계, 이미지 1/1
  8. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 8 단계, 이미지 1/1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Primary Hard-Drive Replacement, Using the Battery Cable: 9 단계, 이미지 1/1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Primary Hard-Drive Replacement, Turn the Computer Over: 10 단계, 이미지 1/1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Primary Hard-Drive Replacement, The Power Button: 11 단계, 이미지 1/1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Tabs: 13 단계, 이미지 1/1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Holes: 14 단계, 이미지 1/1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screws: 15 단계, 이미지 1/1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Primary Hard-Drive Replacement, Connect the Battery Cable: 16 단계, 이미지 1/1
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 17 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 17 단계, 이미지 2/2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Primary Hard-Drive Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 1/3 Dell Alienware 14 Primary Hard-Drive Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 2/3 Dell Alienware 14 Primary Hard-Drive Replacement, Lifting the Secondary Hard-Drive: 18 단계, 이미지 3/3
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Primary Hard-Drive Replacement, Lifting the Hard Drive: 19 단계, 이미지 1/1
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Primary Hard-Drive Replacement, Turn the Assembly Over: 20 단계, 이미지 1/1
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screw: 21 단계, 이미지 1/1
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 22 단계, 이미지 1/1
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Primary Hard-Drive Replacement, Slide and Lift the Hard-Drive: 23 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Slide and Lift the Hard-Drive: 23 단계, 이미지 2/2
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Primary Hard-Drive Replacement, Disconnect the Interposer: 24 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Disconnect the Interposer: 24 단계, 이미지 2/2
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Primary Hard-Drive Replacement, Connect the Interposer: 25 단계, 이미지 1/1
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Primary Hard-Drive Replacement, Placing the Secondary Hard-Drive: 26 단계, 이미지 1/1
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Holes: 27 단계, 이미지 1/1
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screws: 28 단계, 이미지 1/1
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Hole: 29 단계, 이미지 1/1
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screw: 30 단계, 이미지 1/1
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Primary Hard-Drive Replacement, Turn the Hard-Drive Assembly Over: 31 단계, 이미지 1/1
  31. Dell Alienware 14 Primary Hard-Drive Replacement, Slide the Hard-Drive Cable: 32 단계, 이미지 1/1
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Holes: 33 단계, 이미지 1/1
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Primary Hard-Drive Replacement, Disconneting the Hard-Drive Cable: 35 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Disconneting the Hard-Drive Cable: 35 단계, 이미지 2/2
    • Lift the pull-tab to disconnect the primary hard-drive cable from the system-board connector.
  34. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 36 단계, 이미지 1/1
    • Remove the screws that secure the primary hard-drive assembly to the computer base.
  35. Dell Alienware 14 Primary Hard-Drive Replacement, Lifting the Hard-Drive: 37 단계, 이미지 1/1
    • Lift the primary hard-drive assembly off the computer base.
  36. Dell Alienware 14 Primary Hard-Drive Replacement, Disconnecting the Interposer: 38 단계, 이미지 1/1
    • Disconnect the interposer from the primary hard-drive connector.
  37. Dell Alienware 14 Primary Hard-Drive Replacement, Remove the Screws: 39 단계, 이미지 1/1
    • Remove the screws that secure the primary hard-drive to the primary hard-drive bracket.
  38. Dell Alienware 14 Primary Hard-Drive Replacement, Sliding and Lifting the Hard-Drive: 40 단계, 이미지 1/1
    • Slide and lift the primary hard-drive off the primary hard-drive bracket.
  39. Dell Alienware 14 Primary Hard-Drive Replacement, Sliding the Hard-Drive: 41 단계, 이미지 1/2 Dell Alienware 14 Primary Hard-Drive Replacement, Sliding the Hard-Drive: 41 단계, 이미지 2/2
    • Slide the NEW primary hard-drive into the primary hard-drive bracket.
  40. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Holes: 42 단계, 이미지 1/1
    • Align the screw holes on the primary hard-drive with the screw holes on the primary hard-drive bracket.
  41. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screws: 43 단계, 이미지 1/1
    • Replace the screws that secure the primary hard-drive to the primary hard-drive bracket.
  42. Dell Alienware 14 Primary Hard-Drive Replacement, Connect the Interposer: 44 단계, 이미지 1/1
    • Connect the interposer to the primary hard-drive connector.
  43. Dell Alienware 14 Primary Hard-Drive Replacement, Align the Screw Holes: 45 단계, 이미지 1/1
    • Align the screw holes on the primary hard-drive assembly with the screw holes on the computer base.
  44. Dell Alienware 14 Primary Hard-Drive Replacement, Replace the Screws: 46 단계, 이미지 1/1
    • Replace the screws that secure the primary hard-drive assembly to the computer base.
  45. Dell Alienware 14 Primary Hard-Drive Replacement, Connect the Hard-Drive Cable: 47 단계, 이미지 1/1
    • Connect the primary hard-drive cable to the system-board connector.
결론
Terrence15
회원 가입일: 12/18/17
79,309 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,984개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 755
