소개
in this guide, we will be showing you how to remove and replace the Wireless Mini-Card.
필요한 것
Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
Disconnect the battery cable from the system-board connector.
Using the battery cable, lift the battery and release it from the tabs on the computer base.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the computer base.
Slide and remove the wireless-mini card from the system-board connector.
Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
Insert the wireless mini-card at a 45-degree angle into the system-board connector.
Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
Connect the antenna cables to the connectors on the wireless mini-card.
