주요 콘텐츠로 건너뛰기
Dell Alienware 15 Memory Module Replacement
필요한 것
    • After turning the computer off, close the display and turn the computer over.
  1. Dell Alienware 15 Memory Module Replacement, Remove the Back Panel Screws and Lift: 2 단계, 이미지 1개 중 1개
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
  2. Dell Alienware 15 Memory Module Replacement, Optional: Disconnect the Battery: 3 단계, 이미지 1개 중 1개
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
  3. Dell Alienware 15 Memory Module Replacement, Memory Securing Clips: 4 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  4. Dell Alienware 15 Memory Module Replacement, Remove Memory Module: 5 단계, 이미지 1개 중 1개
    • Slide and remove the memory module from any memory-module slots that you would like to repopulate.
  5. Dell Alienware 15 Memory Module Replacement, Adding New Memory Module: 6 단계, 이미지 1개 중 1개
    • Align the notch on the New memory module with the tab on the memory- module slot.
  6. Dell Alienware 15 Memory Module Replacement, Firmly Press the Memory Module Down.: 7 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place. Do this individually for each memory module that is replaced.
    • NOTE : If you do not hear the click, remove the memory module and reinstall it.
결론
To reassemble your device, screw the base panel on again.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 650
