주요 콘텐츠로 건너뛰기
Dell Alienware 15 R3 Battery Replacement
필요한 것
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 1/3 Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 2/3 Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 3/3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: 2 단계, 이미지 1/1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: 4 단계, 이미지 1/2 Dell Alienware 15 R3 Battery Replacement: 4 단계, 이미지 2/2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 1/3 Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 2/3 Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Battery Replacement, Battery: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 1/3 Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 2/3 Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 3/3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jake Nelson
회원 가입일: 09/22/22
581 평판
안내서 7개 작성하였습니다
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 University of North Texas, Team 4-1, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 73
30일 전: 282
전체 시간: 5,456
