주요 콘텐츠로 건너뛰기
Dell Alienware 15 R3 RAM Replacement
필요한 것
  1. Dell Alienware 15 R3 RAM Replacement, Back Case: 1 단계, 이미지 1/3 Dell Alienware 15 R3 RAM Replacement, Back Case: 1 단계, 이미지 2/3 Dell Alienware 15 R3 RAM Replacement, Back Case: 1 단계, 이미지 3/3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 RAM Replacement: 2 단계, 이미지 1/1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • To remove the old RAM sticks, push the metal arms out to the side, using an opening tool or your fingers.
    • Slide the RAM stick out at a 45 degree angle.
    • The RAM sticks are not pictured in this device.
    • To place the new RAM stick, insert it at a 45 degree angle and push it down gently. The metal sides will latch if they are in the correct position.
결론
Jake Nelson
회원 가입일: 09/22/22
581 평판
안내서 7개 작성하였습니다
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 University of North Texas, Team 4-1, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 199
