주요 콘텐츠로 건너뛰기
Dell Alienware 15 R3 Speakers Replacement
필요한 것
  1. Dell Alienware 15 R3 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Remove the 6 M2.5x13 that are holding the back cover on.
    • Remove the 1 M2x3 at the rear of the device that is holding the back cover on.
    • Gently pry on the sides of the back cover with the iFixit Opening Tool to release the tabs.
    • Remove the cover from the computer.
  2. Dell Alienware 15 R3 Speakers Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery.
  3. Dell Alienware 15 R3 Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the M2x3 screw holding the wireless card.
    • Lift and slide the wireless card from its slot.
  4. Dell Alienware 15 R3 Speakers Replacement: 4 단계, 이미지 1/3 Dell Alienware 15 R3 Speakers Replacement: 4 단계, 이미지 2/3 Dell Alienware 15 R3 Speakers Replacement: 4 단계, 이미지 3/3
    • Remove the two M2.5x6 screws connecting the rear cover to the computer.
    • Gently pry the rear cover with the iFixit Opening Tool to release the two tabs on each side.
    • Slide the rear cover from the computer.
  5. Dell Alienware 15 R3 Speakers Replacement: 5 단계, 이미지 1/3 Dell Alienware 15 R3 Speakers Replacement: 5 단계, 이미지 2/3 Dell Alienware 15 R3 Speakers Replacement: 5 단계, 이미지 3/3
    • Remove the light cable located between hard drive port and fan.
    • Open the latch and remove the keyboard cable, keyboard backlight cable, and the macro keys cable.
    • Remove the 11 M2.5x8 screws that secure the computer base.
    • Remove the 2 M2x3 screws.
    • Use a pry tool to separate the base from the computer and then lift the computer base from the computer.
  6. Dell Alienware 15 R3 Speakers Replacement: 6 단계, 이미지 1/2 Dell Alienware 15 R3 Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the M2.5x5 screw holding the battery to the computer.
    • Remove the battery from the computer.
  7. Dell Alienware 15 R3 Speakers Replacement: 7 단계, 이미지 1/2 Dell Alienware 15 R3 Speakers Replacement: 7 단계, 이미지 2/2
    • Disconnect the speaker cable from the motherboard.
    • Lift the speakers from the computer.
결론
Andrew M
회원 가입일: 03/28/23
433 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-4, Harley Spring 2023 IUPUI, Team 2-4, Harley Spring 2023 회원
IUPUI-HARLEY-S23S2G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 194
