소개
In this guide, we will show you how to remove and replace the Third Hard-Drive.
필요한 것
Using the battery cable, lift and release the battery from the tabs on the computer base.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the computer base.
Remove the screws that secure the tertiary hard drive assembly to the computer base.
Using the pull-tab, disconnect the hard-drive cable from the system board.
Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
