주요 콘텐츠로 건너뛰기
Dell Alienware 18 Coin-Cell Battery Replacement
필요한 것
  1. Dell Alienware 18 Coin-Cell Battery Replacement, Before You Begin: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Coin-Cell Battery Replacement, Remove the base cover screws: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Coin-Cell Battery Replacement, Slide the Cover: 3 단계, 이미지 1/1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: 4 단계, 이미지 1/1
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  5. Dell Alienware 18 Coin-Cell Battery Replacement, Removing the Coin-Cell Battery: 5 단계, 이미지 1/1
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  6. Dell Alienware 18 Coin-Cell Battery Replacement, Prying the Coin-Cell Battery: 6 단계, 이미지 1/1
    • Pry up the coin-cell battery from the slot on the system board.
  7. Dell Alienware 18 Coin-Cell Battery Replacement, Placing Coin-Cell Battery: 7 단계, 이미지 1/1
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  8. Dell Alienware 18 Coin-Cell Battery Replacement, Routing the Coin-Cell Battery Cable: 8 단계, 이미지 1/1
    • Route the coin-cell battery cable through the routing guides on the computer base.
  9. Dell Alienware 18 Coin-Cell Battery Replacement, Connecting Coin-Cell Battery: 9 단계, 이미지 1/1
    • Connect the coin-cell battery cable to its connector on the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 426
