주요 콘텐츠로 건너뛰기
소개
In this guide, we will be showing you how to remove and replace the Hard Drive.
부품
지정된 부품이 없습니다.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Loosen the captive screws that secure the hard-drive assembly to the computer base.
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Using the pull-tab, lift the hard-drive  assembly out of the computer base.
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Disconnect the interposer from the hard drives. NOTE: Your computer supports up to three drives.
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Place the NEW primary hard drive  in the hard-drive bracket.
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. If applicable, slide the secondary hard drive into the hard-drive bracket.
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Replace the screws that secure the primary hard drive to the hard-drive bracket.
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Connect the interposer to the hard drives.
    • Connect the interposer to the hard drives.
  11. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  12. Tighten the captive screws that secure  the hard-drive assembly to the computer  base.
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Connect the hard-drive cable to its connector on the system board.
    • Connect the hard-drive cable to its connector on the system board.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
darrius
회원 가입일: 2018년 03월 26일
5,183 평판
안내서 30개 작성하였습니다
Informative Technologies Inc. Informative Technologies Inc. 회원
Community
38 회원들
안내서 1,962개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 274
