이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the hard-drive cable from its connector on the system board.
Loosen the captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
If applicable, slide the secondary hard drive into the hard-drive bracket.
Replace the screws that secure the primary hard drive to the hard-drive bracket.
If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
Tighten the captive screws that secure the hard-drive assembly to the computer base.
다른 2명이 해당 안내서를 완성하였습니다.
