주요 콘텐츠로 건너뛰기
Dell Alienware M11x R3 Battery Replacement
필요한 것
  1. Dell Alienware M11x R3 Battery Replacement, Lower Case: 1 단계, 이미지 1/3 Dell Alienware M11x R3 Battery Replacement, Lower Case: 1 단계, 이미지 2/3 Dell Alienware M11x R3 Battery Replacement, Lower Case: 1 단계, 이미지 3/3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
  3. Dell Alienware M11x R3 Battery Replacement: 3 단계, 이미지 1/1
    • Caution: Ensure computer is completely powered down before attempting to remove the lower case of the computer.
    • Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
  4. Dell Alienware M11x R3 Battery Replacement: 4 단계, 이미지 1/1
    • After removing the two screws, gently lift up the battery with the small plastic tab attached.
  5. Dell Alienware M11x R3 Battery Replacement: 5 단계, 이미지 1/1
    • Caution: Do not attempt to fully remove the battery while the wire is still connected.
    • Lift the battery out of its casing while allowing the wire to remain attached.
  6. Dell Alienware M11x R3 Battery Replacement: 6 단계, 이미지 1/1
    • Behind the battery, locate the PD12 battery wire and gently unplug it.
  7. Dell Alienware M11x R3 Battery Replacement: 7 단계, 이미지 1/1
    • With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
    • Remember to properly dispose of the old battery according to local regulations and recycling guidelines.
결론
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
다른 2명이 해당 안내서를 완성하였습니다.
Richard Maurice
회원 가입일: 03/08/17
534 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 2,158
