소개
This guide provides a concise, step-by-step process for replacing the battery in your Dell Alienware M11x R3 gaming laptop. Replacing the battery can help extend your laptop's life and improve your gaming experience. Before starting, gather the required tools and a compatible replacement battery, and remember to work on a clean, static-free surface while handling internal components carefully.
필요한 것
Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
Remove the bottom cover from the laptop.
Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
다른 2명이 해당 안내서를 완성하였습니다.
