소개
If your Dell Alienware M11x R3 has missing or broken keys that make it difficult to type, then you can use this guide to replace your keyboard.
Safety:
Make sure to power off your device and disconnect it from any power sources before beginning this process.
Please review the General Safety Information for Dell before replacing the keyboard. ++https://support.dellproductcompliance....
필요한 것
Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
Remove the bottom cover from the laptop.
Unscrew the two circled screws holding the battery in place. These screws have retaining washers, so they won't completely detach from the device.
Now unlock and unplug the two ribbons cables underneath the keyboard. They are held in place by black locks.
To unlock them, gently slide a finger nail or spudger tool under them and lift up. You need to do this for both ribbons.
With the old keyboard removed, you can now install your new one and reassemble the computer!
To reassemble your device, follow these instructions in reverse order while attaching the new keyboard.
다른 한 분이 해당 안내서를 완성하였습니다.
