주요 콘텐츠로 건너뛰기
Dell Alienware M11x R3 Wi-Fi Card Replacement
필요한 것
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 1 단계, 이미지 1/3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 1 단계, 이미지 2/3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 1 단계, 이미지 3/3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 1/2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 2/2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Dell Alienware M11x R3 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
결론
Richard Maurice
회원 가입일: 03/08/17
534 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 695
