주요 콘텐츠로 건너뛰기
Dell Alienware M17x R2 Hard Drive Replacement
필요한 것
  1. Dell Alienware M17x R2 Hard Drive Replacement, Loosen the Four Screws: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Loosen the four captive screws that secure the primary hard drive (HDD0).
  2. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 2 단계, 이미지 1/2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 2 단계, 이미지 2/2
    • Using the pull tab, slide the primary hard drive (HDD0) towards the back of the hard drive bay and lift it out.
  3. Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 3 단계, 이미지 1/3 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 3 단계, 이미지 2/3 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 3 단계, 이미지 3/3
    • If your computer has a secondary hard drive (HDD1): 1. Loosen the four captive screws on the secondary hard drive (HDD1). 2. Using the pull tab, lift the secondary hard drive (HDD1) out of the hard drive bay.
  4. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 1/1
    • Remove the four screws that secure the hard drive bracket to the hard drive.
  5. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 5 단계, 이미지 1/2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 5 단계, 이미지 2/2
    • Slide the hard drive out of the hard drive bracket.
  6. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: 6 단계, 이미지 1/2 Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: 6 단계, 이미지 2/2
    • Remove the interposer from the secondary hard drive (HDD1), if applicable.
  7. Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: 7 단계, 이미지 1/2 Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: 7 단계, 이미지 2/2
    • Connect the NEW interposer to the secondary hard drive (HDD1), if applicable.
  8. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 8 단계, 이미지 1/2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 8 단계, 이미지 2/2
    • Slide the hard drive into the hard drive bracket.
  9. Dell Alienware M17x R2 Hard Drive Replacement, Replace the Screws: 9 단계, 이미지 1/1
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  10. Dell Alienware M17x R2 Hard Drive Replacement, Placing the Hard Drive: 10 단계, 이미지 1/1
    • Place the hard drive in the hard drive bay.
  11. Dell Alienware M17x R2 Hard Drive Replacement, Align and Tighten the Screws: 11 단계, 이미지 1/1
    • If your computer has a secondary hard drive (HDD1), align and tighten the four captive screws that secure the hard drive to the hard drive bay.
    • Align and and tighten the four captive screws that secure the primary hard drive (HDD0) to the hard drive bay.
결론
Terrence15
회원 가입일: 12/18/17
79,091 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 2,070
