소개
In this guide, we will show you how to remove and replace the Hard Drive.
필요한 것
Loosen the four captive screws that secure the primary hard drive (HDD0).
Using the pull tab, slide the primary hard drive (HDD0) towards the back of the hard drive bay and lift it out.
If your computer has a secondary hard drive (HDD1): 1. Loosen the four captive screws on the secondary hard drive (HDD1). 2. Using the pull tab, lift the secondary hard drive (HDD1) out of the hard drive bay.
Remove the four screws that secure the hard drive bracket to the hard drive.
Remove the interposer from the secondary hard drive (HDD1), if applicable.
Connect the NEW interposer to the secondary hard drive (HDD1), if applicable.
Replace the four screws that secure the hard drive bracket to the hard drive.
If your computer has a secondary hard drive (HDD1), align and tighten the four captive screws that secure the hard drive to the hard drive bay.
Align and and tighten the four captive screws that secure the primary hard drive (HDD0) to the hard drive bay.
