소개
The battery is a very common part to need to replace on a computer, especially as it becomes older. This is a very straightforward process and will only require removing a few screws and unplugging a cable. It should only take a couple of minutes, and there is little damage to be done.
필요한 것
Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
다른 8명이 해당 안내서를 완성하였습니다.
