주요 콘텐츠로 건너뛰기
Dell Chromebook 11 3180 Keyboard Replacement
필요한 것
  1. Dell Chromebook 11 3180 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Keyboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Keyboard Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Keyboard Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Keyboard Replacement: 5 단계, 이미지 1/1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/1
    • Disconnect the ribbon cable from the motherboard. To do this, lift up the black tab hinge securing the ribbon cable and pull the cable up and then out of the port.
  7. Dell Chromebook 11 3180 Keyboard Replacement: 7 단계, 이미지 1/1
    • Release the keyboard from the body. To do this, push on the two keyboard release holes with something thin and cylindrical like a spudger or a pencil.
  8. Dell Chromebook 11 3180 Keyboard Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard from the body. To do this, use a plastic prying tool to get under the keyboard and pry it up from the computer body.
  9. Dell Chromebook 11 3180 Keyboard Replacement: 9 단계, 이미지 1/1
    • Once you have separated the keyboard and the body using a spudger or plastic opening tool, use your hands to pull it away from and off of the computer.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Devon Paul
회원 가입일: 04/26/17
1,206 평판
안내서 6개 작성하였습니다
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G1
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
How I will fix the chromebook 11 now?
Federico Vazquez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 33
전체 시간: 7,405
