주요 콘텐츠로 건너뛰기
Dell Chromebook 11 3180 Speakers Replacement
필요한 것
  1. Dell Chromebook 11 3180 Speakers Replacement, Back Cover: 1 단계, 이미지 1/1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Speakers Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Speakers Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Speakers Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Speakers Replacement: 5 단계, 이미지 1/1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Speakers Replacement, Speakers: 6 단계, 이미지 1/3 Dell Chromebook 11 3180 Speakers Replacement, Speakers: 6 단계, 이미지 2/3 Dell Chromebook 11 3180 Speakers Replacement, Speakers: 6 단계, 이미지 3/3
    • Locate and gently pull the wire harness (small plastic box with wires leading to black audio speakers) directly out of the connector on the motherboard.
    • Some components are not shown in pictures for simplicity. There is no need to remove any of the missing components to successfully remove the speakers.
  7. Dell Chromebook 11 3180 Speakers Replacement: 7 단계, 이미지 1/3 Dell Chromebook 11 3180 Speakers Replacement: 7 단계, 이미지 2/3 Dell Chromebook 11 3180 Speakers Replacement: 7 단계, 이미지 3/3
    • Remove any existing tape attached to the audio wire you unplugged in the previous step.
    • Gently lift and remove speakers.
    • No screws should be removed
결론
다른 3명이 해당 안내서를 완성하였습니다.
George Erie
회원 가입일: 04/26/17
327 평판
안내서 2개 작성하였습니다
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 666
