주요 콘텐츠로 건너뛰기
Dell Chromebook 11 3189 Display Assembly Replacement
필요한 것
  1. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Display Hinge: 1 단계, 이미지 1/1
    • Lift the display assembly away from the computer.
  2. Dell Chromebook 11 3189 Display Assembly Replacement, Place the Display Assembly: 3 단계, 이미지 1/1
    • Place the display assembly to align with the screw holders on the computer.
  3. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Screws: 4 단계, 이미지 1/1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  4. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Sensor Cable: 5 단계, 이미지 1/1
    • Flip over the computer and connect the sensor cable on the system board.
  5. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Display Cable: 6 단계, 이미지 1/1
    • Connect the display cable to the connector on the system board.
  6. Dell Chromebook 11 3189 Display Assembly Replacement, Securing the Screws: 7 단계, 이미지 1/1
    • Place the metal bracket over the (display cable) connector, and tighten the M2.0x3.0 screws to secure the display cable to the computer.
  7. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the WLAN cables.: 8 단계, 이미지 1/1
    • Connect the WLAN cables.
  8. Dell Chromebook 11 3189 Display Assembly Replacement, Placing the Metal Bracket: 9 단계, 이미지 1/1
    • Place the metal bracket, and tighten the M2.0x3.0 screw to the WLAN cable on the system board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,161 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
Hola, he remplazado la pantalla. El montaje perfecto pero no enciende. Hay que hacer algo en concreto? Me refiero para que detecte esta pantalla nueva.
Muchas gracias
jordi fernandez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 27
전체 시간: 1,821
