주요 콘텐츠로 건너뛰기
Dell Chromebook 11 CB1C13 Battery Replacement
필요한 것
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: 1 단계, 이미지 1/3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: 1 단계, 이미지 2/3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: 2 단계, 이미지 1/2 Dell Chromebook 11 CB1C13 Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: 3 단계, 이미지 1/2 Dell Chromebook 11 CB1C13 Battery Replacement: 3 단계, 이미지 2/2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
결론
To replace your Dell Chromebook 11 battery, follow these instructions in order.
다른 2명이 해당 안내서를 완성하였습니다.
Jerry Geffrard
회원 가입일: 03/25/15
334 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 1,322
