주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show you how to replace the fan. It is very common for a fan to collect dust, and without proper cooling, a device may overheat and suffer permanent internal damage. Knowing how to remove a fan for proper cleaning can be beneficial for the condition and longevity of a laptop.
  1. Make sure that device is fully powered down before attempting to open the back case. Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver. Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Locate the two wires that connect the fan to the device. One black, and one white. Move these wires off of the fan by gently pulling on them. Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool. The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work. The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
결론
Bryan Allen
회원 가입일: 2017년 10월 20일
246 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G6
3 회원들
안내서 7개 작성하였습니다
Ram?
Can i change the ram?
flip - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 476
