주요 콘텐츠로 건너뛰기
Dell Chromebook 11 CB1C13 Fan Replacement
필요한 것
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 1 단계, 이미지 1/3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 1 단계, 이미지 2/3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 1 단계, 이미지 3/3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 2 단계, 이미지 1/3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 2 단계, 이미지 2/3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 2 단계, 이미지 3/3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: 3 단계, 이미지 1/3 Dell Chromebook 11 CB1C13 Fan Replacement: 3 단계, 이미지 2/3 Dell Chromebook 11 CB1C13 Fan Replacement: 3 단계, 이미지 3/3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
결론
Bryan Allen
회원 가입일: 10/20/17
272 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G6
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Ram?
Can i change the ram?
flip - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 17
전체 시간: 1,035
