주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The LCD screen is the main method for a device to portray information to the user. Even the slightest bit of damage to this can cause major changes in the display, and will require a replacement.
  1. Make sure that device is fully powered down before attempting to open the back case. Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver. Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Locate the two hinges on the corners of the device. Unscrew the 5 2mm Phillips #00 screws in the hinges. Pull the hinges up and slide bottom cover out
    • Locate the two hinges on the corners of the device.
    • Unscrew the 5 2mm Phillips #00 screws in the hinges.
    • Pull the hinges up and slide bottom cover out
    • Gently remove the cover since it is still connected to the device by some wires
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Locate the two cables that connect the top panel to the device. One black, and one white. Remove these two cables by grabbing the golden ends with your fingers, and gently pulling straight up.
    • Locate the two cables that connect the top panel to the device. One black, and one white.
    • Remove these two cables by grabbing the golden ends with your fingers, and gently pulling straight up.
    • Remove pin port lifting up the hinge.
  5. Locate the seam between the screen cover, and the top panel Starting at one of the hinge corners, take a thin metal prying tool and gently insert it into the seam. Gently push the tool down towards the top panel until you feel the screen cover disconnect.
    • Locate the seam between the screen cover, and the top panel
    • Starting at one of the hinge corners, take a thin metal prying tool and gently insert it into the seam.
    • Gently push the tool down towards the top panel until you feel the screen cover disconnect.
    • Repeat this process all around the screen cover until it is completely disconnected from the top panel.
    • During this process, you might hear a rough snapping sound. This is normal, and is just the sound of the screen cover's connections to the top panel coming apart.
    • Make sure to be gentle with your prying, and to move in small increments around the screen cover during this process. This is to prevent any cracks or damage to the cover, which could be harmful.
  6. Locate 6 2mm phillips #00 screws that connect the LCD display to the screen panel. Unscrew the 6 2mm Philips #00 screws. Carefully flip the LCD display, which is still connected to the device, over the hinges so that it is laying down next to the screen panel.
    • Locate 6 2mm phillips #00 screws that connect the LCD display to the screen panel.
    • Unscrew the 6 2mm Philips #00 screws.
    • Carefully flip the LCD display, which is still connected to the device, over the hinges so that it is laying down next to the screen panel.
  7. Locate the gold video cable that still connects the LCD cable to the display. There will be a piece of tape on the cable. Carefully peel this off, and the pins should come out easily.
    • Locate the gold video cable that still connects the LCD cable to the display.
    • There will be a piece of tape on the cable. Carefully peel this off, and the pins should come out easily.
    • The pins are very small and delicate. Any pressure or twisting on them may cause irreversible damage, and require a replacement of the cable.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Jerry Geffrard
회원 가입일: 2015년 03월 25일
319 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G6
3 회원들
안내서 7개 작성하였습니다
Zoom in a little more on the WLAN chip so it’s easier to see what wire goes where.
GanSolo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 1,134
