주요 콘텐츠로 건너뛰기
Dell Chromebook 11-3120 Back Panel Replacement
필요한 것
  1. Dell Chromebook 11-3120 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Chromebook 11-3120 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Back Panel Replacement: 2 단계, 이미지 1/2 Dell Chromebook 11-3120 Back Panel Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joseph Silveira
회원 가입일: 10/19/17
401 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 558
