주요 콘텐츠로 건너뛰기
Dell Chromebook 11-3120 Battery Replacement
필요한 것
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 1 단계, 이미지 1/1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: 2 단계, 이미지 1/2 Dell Chromebook 11-3120 Battery Replacement: 2 단계, 이미지 2/2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: 3 단계, 이미지 1/1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 4 단계, 이미지 1/1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
결론
Dalton D
회원 가입일: 12/08/17
2,569 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 384
