주요 콘텐츠로 건너뛰기
Dell Chromebook 11-3120 Battery Replacement
필요한 것
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 1 단계, 이미지 1개 중 1개
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: 2 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: 3 단계, 이미지 1개 중 1개
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 4 단계, 이미지 1개 중 1개
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
결론
작성자
1다른 기여자 명과 함께
May D
회원 가입일: 12/08/17
2,722 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 546
