주요 콘텐츠로 건너뛰기
Dell Chromebook 11-3120 Daughterboard Replacement
필요한 것
  1. Dell Chromebook 11-3120 Daughterboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Daughterboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Daughterboard Replacement: 2 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Daughterboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Daughterboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Daughterboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Daughterboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
  5. Dell Chromebook 11-3120 Daughterboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Daughterboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 2개
    • Disconnect the bridge connection ribbon cable from the motherboard.
  6. Dell Chromebook 11-3120 Daughterboard Replacement: 6 단계, 이미지 2개 중 1개 Dell Chromebook 11-3120 Daughterboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using a JIS #0 screwdriver, unscrew the three 4mm screws securing the daughterboard in place.
  7. Dell Chromebook 11-3120 Daughterboard Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully lift out the daughterboard with the right-hand USB port from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mitchell Stevens
회원 가입일: 10/19/17
406 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 14
전체 시간: 1,129
