주요 콘텐츠로 건너뛰기
Dell Chromebook 11-3120 Speakers Replacement
필요한 것
  1. Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Speakers Replacement: 2 단계, 이미지 1/2 Dell Chromebook 11-3120 Speakers Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Speakers Replacement, Battery: 3 단계, 이미지 1/2 Dell Chromebook 11-3120 Speakers Replacement, Battery: 3 단계, 이미지 2/2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Speakers Replacement: 4 단계, 이미지 1/1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
  5. Dell Chromebook 11-3120 Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Gently remove the 4-pin connector that connects the speakers to the motherboard.
  6. Dell Chromebook 11-3120 Speakers Replacement: 6 단계, 이미지 1/1
    • Remove the tape securing it to the plastic casing of the device.
  7. Dell Chromebook 11-3120 Speakers Replacement: 7 단계, 이미지 1/1
    • Carefully lift out the right speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
  8. Dell Chromebook 11-3120 Speakers Replacement: 8 단계, 이미지 1/1
    • Moving down the cable, remove the left speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Silveira
회원 가입일: 10/19/17
401 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 353
