주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 Battery Replacement
필요한 것
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 13-7310 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: 5 단계, 이미지 1/1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
결론
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Caleb S Whitener
회원 가입일: 09/08/17
225 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 1,258
