주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 Cooling Fan Replacement
필요한 것
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 1/2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2/2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: 4 단계, 이미지 1/2 Dell Chromebook 13-7310 Cooling Fan Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
결론
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
Alec Thomas
회원 가입일: 09/08/17
120 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 481
