주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 IO Board Replacement
필요한 것
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: 3 단계, 이미지 1/1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: 4 단계, 이미지 1/1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: 5 단계, 이미지 1/1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: 6 단계, 이미지 1/1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: 7 단계, 이미지 1/1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: 8 단계, 이미지 1/1
    • Remove the IO board.
결론
Damon
회원 가입일: 11/01/18
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 323
