주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 Keyboard Replacement
필요한 것
  1. Dell Chromebook 13-7310 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Keyboard Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Keyboard Replacement, Battery: 3 단계, 이미지 1/1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Keyboard Replacement: 5 단계, 이미지 1/1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Keyboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Gently pull to unplug fan connector.
  7. Dell Chromebook 13-7310 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove 4 screws securing heat sink.
  8. Dell Chromebook 13-7310 Keyboard Replacement: 8 단계, 이미지 1/1
    • Lift away heat sink.
  9. Dell Chromebook 13-7310 Keyboard Replacement: 9 단계, 이미지 1/1
    • Remove the eight 2mm screws securing the motherboard in place.
  10. Dell Chromebook 13-7310 Keyboard Replacement: 10 단계, 이미지 1/1
    • Release cable for the LED charging indicator by pulling up on connector.
  11. Dell Chromebook 13-7310 Keyboard Replacement: 11 단계, 이미지 1/1
    • Gently remove the cable.
  12. Dell Chromebook 13-7310 Keyboard Replacement: 12 단계, 이미지 1/1
    • Pull up on connector tab to release IO board cable.
  13. Dell Chromebook 13-7310 Keyboard Replacement: 13 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement: 13 단계, 이미지 2/2
    • Pull up on connector tab to release touchpad cable.
  14. Dell Chromebook 13-7310 Keyboard Replacement: 14 단계, 이미지 1/1
    • Release the keyboard backlight cable.
  15. Dell Chromebook 13-7310 Keyboard Replacement: 15 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement: 15 단계, 이미지 2/2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  16. Dell Chromebook 13-7310 Keyboard Replacement: 16 단계, 이미지 1/1
    • Release eDP cable.
  17. Dell Chromebook 13-7310 Keyboard Replacement: 17 단계, 이미지 1/1
    • Release dc-in cable.
  18. Dell Chromebook 13-7310 Keyboard Replacement: 18 단계, 이미지 1/1
    • Gently lift up the motherboard to remove it.
  19. Dell Chromebook 13-7310 Keyboard Replacement, Cooling Fan: 19 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement, Cooling Fan: 19 단계, 이미지 2/2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  20. Dell Chromebook 13-7310 Keyboard Replacement: 20 단계, 이미지 1/2 Dell Chromebook 13-7310 Keyboard Replacement: 20 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
  21. Dell Chromebook 13-7310 Keyboard Replacement, IO Board: 21 단계, 이미지 1/1
    • Remove the single 2mm screw securing the IO board to the laptop.
  22. Dell Chromebook 13-7310 Keyboard Replacement: 22 단계, 이미지 1/1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  23. Dell Chromebook 13-7310 Keyboard Replacement: 23 단계, 이미지 1/1
    • Remove the IO board.
  24. Dell Chromebook 13-7310 Keyboard Replacement, Keyboard: 24 단계, 이미지 1/1
    • Remove all screws.
    • All screws for the keyboard will have a "K" next to them.
  25. Dell Chromebook 13-7310 Keyboard Replacement: 25 단계, 이미지 1/1
    • Gently lift up the keyboard and remove.
    • This step does not require much force. If you have to use a lot of force to lift the keyboard, check to make sure you didn't miss a screw.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Damon
회원 가입일: 11/01/18
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G1
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
I’ve never pulled apart a computer before, and this guide was perfect! thanks
Owen Thomas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 737
