주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 Mousepad Replacement
필요한 것
  1. Dell Chromebook 13-7310 Mousepad Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 13-7310 Mousepad Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Mousepad Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: 3 단계, 이미지 1/3 Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: 3 단계, 이미지 2/3 Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: 3 단계, 이미지 3/3
    • The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side.
    • Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard.
    • To remove the battery, lift up on one side to get you fingers underneath and lift away.
  4. Dell Chromebook 13-7310 Mousepad Replacement: 4 단계, 이미지 1/3 Dell Chromebook 13-7310 Mousepad Replacement: 4 단계, 이미지 2/3 Dell Chromebook 13-7310 Mousepad Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the six 2mm screws located around the maouse pad cover.
    • Using either fingernails or tweezers, lift the black cover on the ribbon cable and pull the cable loose from he motherboard.
    • Once the ribbon cable is disconnected lift up on the back cove to remove it and expose the mouse pad.
  5. Dell Chromebook 13-7310 Mousepad Replacement: 5 단계, 이미지 1/1
    • Now that the mouse pad is exposed, lift the assembly to remove the mouse pad.
결론
Congratulations! You have successfully removed the mouse pad on your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
Kayla McDaniel
회원 가입일: 09/08/17
213 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 547
