주요 콘텐츠로 건너뛰기
Dell Chromebook 13-7310 Network Card Replacement
필요한 것
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Dell Chromebook 13-7310 Network Card Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: 6 단계, 이미지 2개 중 1개 Dell Chromebook 13-7310 Network Card Replacement, Network Card: 6 단계, 이미지 2개 중 2개
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
결론
작성자
3다른 기여자 명과 함께
Brett Raymond
회원 가입일: 11/01/18
469 평판
안내서 3개를 작성함
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 660
