주요 콘텐츠로 건너뛰기
Dell Chromebook 3100 2-in-1 Battery Replacement
필요한 것
  1. Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Battery Replacement: 2 단계, 이미지 1/2 Dell Chromebook 3100 2-in-1 Battery Replacement: 2 단계, 이미지 2/2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: 3 단계, 이미지 1/2 Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Battery Replacement: 4 단계, 이미지 1/3 Dell Chromebook 3100 2-in-1 Battery Replacement: 4 단계, 이미지 2/3 Dell Chromebook 3100 2-in-1 Battery Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Battery Replacement: 5 단계, 이미지 1/2 Dell Chromebook 3100 2-in-1 Battery Replacement: 5 단계, 이미지 2/2
    • Carefully remove the battery from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maria Williams
회원 가입일: 09/02/21
254 평판
안내서 1개 작성함
Gateway, Team 1-1, Pee Fall 2021 Gateway, Team 1-1, Pee Fall 2021 회원
GCC-PEE-F21S1G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 52
전체 시간: 1,368
