주요 콘텐츠로 건너뛰기
Dell Chromebook 3110 Speakers Replacement
필요한 것
  1. Dell Chromebook 3110 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Speakers Replacement: 2 단계, 이미지 1/1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Speakers Replacement: 3 단계, 이미지 1/1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Speakers Replacement: 4 단계, 이미지 1/1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Speakers Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery out of the laptop.
  6. Dell Chromebook 3110 Speakers Replacement, Speakers: 6 단계, 이미지 1/1
    • Remove adhesive tape securing the speaker cable to the motherboard, and disconnect the speaker cable from the motherboard.
  7. Dell Chromebook 3110 Speakers Replacement: 7 단계, 이미지 1/1
    • Carefully remove the speaker cable from the retention clips towards the bottom of the device.
  8. Dell Chromebook 3110 Speakers Replacement: 8 단계, 이미지 1/1
    • Lift and remove the speakers from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Neblo
회원 가입일: 02/24/23
177 평판
안내서 1개 작성함
Marist, Team 1-6, Chaterdon Spring 2023 Marist, Team 1-6, Chaterdon Spring 2023 회원
MARS-CHATERDON-S23S1G6
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 115
