주요 콘텐츠로 건너뛰기
Dell Chromebook 3180 Charging Port Replacement
필요한 것
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: 1 단계, 이미지 1/2 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: 1 단계, 이미지 2/2
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: 5 단계, 이미지 1/1
    • Secure all 7 screws with a Phillips #0
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jon
회원 가입일: 08/18/13
3,921 평판
안내서 22개 작성하였습니다
댓글 한 개
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 1,070
