주요 콘텐츠로 건너뛰기
Dell DJ 2nd Generation Disassembly
필요한 것
  1. Dell DJ 2nd Generation Disassembly, Remove lock switch slider: 1 단계, 이미지 1/1
    • The lock switch slider can be removed with a small prying tool. Make sure it doesn't go flying across the room!
  2. Dell DJ 2nd Generation Disassembly, Remove bottom cover: 2 단계, 이미지 1/1
    • The cover is affixed with adhesive. It can be pried off.
    • Don't start with an opening pick. Instead, use an iFixit Opening Tool and start around the charging port.
    • When it's lifted up far enough, wedge an opening pick between the case and the cover.
    • If necessary, you can use the Jimmy to pry around the edges. Be gentle, as it's very easy to damage the aluminum case.
  3. Dell DJ 2nd Generation Disassembly, Remove top cover: 3 단계, 이미지 1/1
    • The top cover put up more of a fight. I had to use the Jimmy for this one.
    • Again, use caution to avoid damaging the case. It's also important to avoid bending the top cover sharply.
  4. Dell DJ 2nd Generation Disassembly, Remove screws and metal plates: 4 단계, 이미지 1/2 Dell DJ 2nd Generation Disassembly, Remove screws and metal plates: 4 단계, 이미지 2/2
    • There are eight Philips #00 screws, one on each corner at both ends of the device.
    • I don't recommend using tweezers to remove the plates like I did. You might bend the tips.
  5. Dell DJ 2nd Generation Disassembly, Remove battery: 5 단계, 이미지 1/1
    • Be careful to avoid bending the battery. It is very thin and prone to damage.
    • Disconnect the battery connector. Then, gently pull the wires until the battery slides out.
    • If the battery doesn't slide out, use a blunt but thin tool (such as the flat end of an iFixit Spudger) to push the battery from the other end.
  6. Dell DJ 2nd Generation Disassembly, Remove the navigation wheel: 6 단계, 이미지 1/1
    • Try something other than a Jimmy first. It can damage both the encoder's housing and the aluminum case.
    • It may help to push the internals towards the top slightly, but they won't come out yet.
  7. Dell DJ 2nd Generation Disassembly, Slide the guts out: 7 단계, 이미지 1/1
    • The internals should come out easily. If it seems to catch on something, wiggle it around gently.
    • Be careful not to scratch the display.
  8. Dell DJ 2nd Generation Disassembly, Remove the display (part 1): 8 단계, 이미지 1/1
    • Lift up the tabs on both sides.
    • Lift the left side of the display completely.
    • Don't force the tabs on the right; just unlatch them and push them up slightly so they don't snap back into place.
  9. Dell DJ 2nd Generation Disassembly, Remove the display (part 2): 9 단계, 이미지 1/1
    • Use your soldering iron to melt the solder holding the metal frame to the board. Use a small tool to gently pry the display up.
  10. Dell DJ 2nd Generation Disassembly, Remove the display (part 3): 10 단계, 이미지 1/1
    • Push the ends of the brown latch towards the screen, then remove the display.
  11. Dell DJ 2nd Generation Disassembly, Unscrew the hard drive: 11 단계, 이미지 1/1
    • There are four Philips #00 screws holding the hard drive in. They're the same as the eight screws you removed earlier, so don't worry about mixing them up.
  12. Dell DJ 2nd Generation Disassembly, Disconnect the hard drive: 12 단계, 이미지 1/2 Dell DJ 2nd Generation Disassembly, Disconnect the hard drive: 12 단계, 이미지 2/2
    • Peel back the red tape. Then, lift up the latch and pull the cable out.
  13. Dell DJ 2nd Generation Disassembly, Disconnect the hard drive (again): 13 단계, 이미지 1/2 Dell DJ 2nd Generation Disassembly, Disconnect the hard drive (again): 13 단계, 이미지 2/2
    • This connector is the same as the one on the mainboard. The latch is beige on this one.
  14. Dell DJ 2nd Generation Disassembly, Remove the hard drive from its frame: 14 단계, 이미지 1/1
    • Gently push on the label side of the hard drive to remove it from the frame.
  15. Dell DJ 2nd Generation Disassembly, Remove the keypad: 15 단계, 이미지 1/2 Dell DJ 2nd Generation Disassembly, Remove the keypad: 15 단계, 이미지 2/2
    • Push the brown latch towards the keypad, then pull the cable out.
    • The keypad is only held on by a bit of double-sided tape on the RAM chip.
결론
And you’re done!
다른 한 분이 해당 안내서를 완성하였습니다.
Henry Jeynes
회원 가입일: 08/06/20
470 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 278
