소개
This guide should be followed closely before attempting to repair your device. Follow the steps in great detail to ensure the success of your repair.
필요한 것
Inspect your device and be sure that it matches the device that this guide is disassembling.
Familiarize yourself with the specific design of the device.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
다른 한 분이 해당 안내서를 완성하였습니다.
