주요 콘텐츠로 건너뛰기
Dell DJ Disassembly
필요한 것
  1. Dell DJ Disassembly, Dell DJ Disassembly: 1 단계, 이미지 1/3 Dell DJ Disassembly, Dell DJ Disassembly: 1 단계, 이미지 2/3 Dell DJ Disassembly, Dell DJ Disassembly: 1 단계, 이미지 3/3
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  2. Dell DJ Disassembly: 2 단계, 이미지 1/3 Dell DJ Disassembly: 2 단계, 이미지 2/3 Dell DJ Disassembly: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
    • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
    • Be sure to keep the 4mm screws together and organized on the device magnet plate.
  3. Dell DJ Disassembly: 3 단계, 이미지 1/3 Dell DJ Disassembly: 3 단계, 이미지 2/3 Dell DJ Disassembly: 3 단계, 이미지 3/3
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  4. Dell DJ Disassembly: 4 단계, 이미지 1/3 Dell DJ Disassembly: 4 단계, 이미지 2/3 Dell DJ Disassembly: 4 단계, 이미지 3/3
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
William Abel
회원 가입일: 01/28/16
164 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 회원
USFSM-STEWART-S16S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
How did you get the logic board to slide past the scroll wheel ?
kf4qic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 596
