주요 콘텐츠로 건너뛰기
Dell Desktop Optiplex 960 RAM Replacement
  1. Dell Desktop Optiplex 960 RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Back up all files and shut the computer down safely.
  2. Dell Desktop Optiplex 960 RAM Replacement: 2 단계, 이미지 2개 중 1개 Dell Desktop Optiplex 960 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully unplug the cords located at the back of the computer (i.e. Power, Monitor, USB, etc).
    • Switch off the electrical connection before unplugging any cords to avoid electric shock.
  3. Dell Desktop Optiplex 960 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the trigger located at the bottom of the desktop to unlock the desktop back. This may look different on each individual's computer.
  4. Dell Desktop Optiplex 960 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift up the side panel by pulling it upward while holding the trigger.
  5. Dell Desktop Optiplex 960 RAM Replacement: 5 단계, 이미지 2개 중 1개 Dell Desktop Optiplex 960 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • To unlock the RAM, press down the two clips/buttons located on both end of the RAM holder.
  6. Dell Desktop Optiplex 960 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the RAM from the slot.
  7. Dell Desktop Optiplex 960 RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Ensure that your new RAM chip matches the same shape as the one you removed from your computer.
  8. Dell Desktop Optiplex 960 RAM Replacement: 8 단계, 이미지 2개 중 1개 Dell Desktop Optiplex 960 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Place the new RAM chip into the slot and gently press it down until the clips on either side clasp around it.
  9. Dell Desktop Optiplex 960 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Press the wall of the computer back into place until you hear a click from the lock engaging.
  10. Dell Desktop Optiplex 960 RAM Replacement: 10 단계, 이미지 2개 중 1개 Dell Desktop Optiplex 960 RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Plug the cords back and power on your computer.
    • Your computer should be back up and running.
결론
After completing steps 1-12, your PC will be up running successfully. If the see your computer is still showing issues, repeat the instructions carefully. However, if the device is still not running properly, the problem is associated with the hardware (RAM), which is not considered for this guideline.
작성자
4다른 기여자 명과 함께
Mercedes Carter
회원 가입일: 03/03/20
181 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 35
전체 시간: 1,149
