주요 콘텐츠로 건너뛰기
Dell Dimension 2300 Hard Drive Replacement
필요한 것
    • Shut down the computer through the Start menu.
    • Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
    • Remove the bracket-securing screw, and then remove the drive bracket from the computer.
    • Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
    • Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
James Walker
회원 가입일: 10/04/17
287 평판
안내서 1개 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 2개
Some pictures would be nice.
guardian10 - 답글
No power arrived while i switch on the button of compiutor
Daniel Hailemariam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 50
전체 시간: 1,761
