이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
Remove the bracket-securing screw, and then remove the drive bracket from the computer.
Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Some pictures would be nice.
guardian10 - 답글
No power arrived while i switch on the button of compiutor
