소개
Use this guide to replace the fan inside of your Dell Dimension 4600.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
