주요 콘텐츠로 건너뛰기
Dell Dimension 4600 RAM Replacement
필요한 것
  1. Dell Dimension 4600 RAM Replacement, Side Panel: 1 단계, 이미지 1/1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 RAM Replacement: 2 단계, 이미지 1/1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 RAM Replacement: 3 단계, 이미지 1/1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
  5. Dell Dimension 4600 RAM Replacement: 5 단계, 이미지 1/2 Dell Dimension 4600 RAM Replacement: 5 단계, 이미지 2/2
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
  6. Dell Dimension 4600 RAM Replacement: 6 단계, 이미지 1/2 Dell Dimension 4600 RAM Replacement: 6 단계, 이미지 2/2
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Daniel Crawford
회원 가입일: 10/10/11
1,021 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 회원
CPSU-REGAN-F11S6G10
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 10,175
