주요 콘텐츠로 건너뛰기
Dell Dimension 4600 Sound Card Replacement
필요한 것
  1. Dell Dimension 4600 Sound Card Replacement, Side Panel: 1 단계, 이미지 1/1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Sound Card Replacement: 2 단계, 이미지 1/1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Sound Card Replacement: 3 단계, 이미지 1/1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Sound Card Replacement, Sound Card: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Very important at this point you connect your antistatic wrist strap to the chassis because the computer is no longer connected to ground at the power source. There is potential for static discharge which could destroy components.
  5. Dell Dimension 4600 Sound Card Replacement: 5 단계, 이미지 1/1
    • Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
  6. Dell Dimension 4600 Sound Card Replacement: 6 단계, 이미지 1/1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
  7. Dell Dimension 4600 Sound Card Replacement: 7 단계, 이미지 1/3 Dell Dimension 4600 Sound Card Replacement: 7 단계, 이미지 2/3 Dell Dimension 4600 Sound Card Replacement: 7 단계, 이미지 3/3
    • Locate and remove the white connector on the sound card by pulling on the black cable.
  8. Dell Dimension 4600 Sound Card Replacement: 8 단계, 이미지 1/2 Dell Dimension 4600 Sound Card Replacement: 8 단계, 이미지 2/2
    • Grasp the Sound Card and pull it up and out of it's slot.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Arvind
회원 가입일: 10/12/11
395 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 회원
CPSU-REGAN-F11S6G10
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 5,257
