주요 콘텐츠로 건너뛰기
Dell E193FPc Display Bezel Replacement
필요한 것
  1. Dell E193FPc Display Bezel Replacement, Stand: 1 단계, 이미지 1/1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: 2 단계, 이미지 1/1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: 3 단계, 이미지 1/2 Dell E193FPc Display Bezel Replacement, Display Bezel: 3 단계, 이미지 2/2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: 4 단계, 이미지 1/2 Dell E193FPc Display Bezel Replacement: 4 단계, 이미지 2/2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: 5 단계, 이미지 1/3 Dell E193FPc Display Bezel Replacement: 5 단계, 이미지 2/3 Dell E193FPc Display Bezel Replacement: 5 단계, 이미지 3/3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Mackenzie Keane
회원 가입일: 10/04/11
514 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G36
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 4,273
