주요 콘텐츠로 건너뛰기
Dell G5 5000 Gaming PC Ram Replacement
  1. Dell G5 5000 Gaming PC Ram Replacement, System Ram: 1 단계, 이미지 1/2 Dell G5 5000 Gaming PC Ram Replacement, System Ram: 1 단계, 이미지 2/2
    • Unplug any cables plugged into the computer.
    • Place the computer system on its side to have easier access to the internals.
  2. Dell G5 5000 Gaming PC Ram Replacement: 2 단계, 이미지 1/2 Dell G5 5000 Gaming PC Ram Replacement: 2 단계, 이미지 2/2
    • Unscrew the captive thumbscrews counterclockwise until they become loose and hang down from the holes.
  3. Dell G5 5000 Gaming PC Ram Replacement: 3 단계, 이미지 1/3 Dell G5 5000 Gaming PC Ram Replacement: 3 단계, 이미지 2/3 Dell G5 5000 Gaming PC Ram Replacement: 3 단계, 이미지 3/3
    • Use the handle on the back of the system and pull it towards the back of the computer to slide panel to the side.
    • Lift the side panel up to remove it off the system.
  4. Dell G5 5000 Gaming PC Ram Replacement: 4 단계, 이미지 1/3 Dell G5 5000 Gaming PC Ram Replacement: 4 단계, 이미지 2/3 Dell G5 5000 Gaming PC Ram Replacement: 4 단계, 이미지 3/3
    • Push down on both latch clips next to the ram stick.
  5. Dell G5 5000 Gaming PC Ram Replacement: 5 단계, 이미지 1/2 Dell G5 5000 Gaming PC Ram Replacement: 5 단계, 이미지 2/2
    • Remove the stick of ram by lifting it from the socket.
    • Avoid holding the stick from the flat sides, instead, hold it from the edges since you could statically shock the module and damage it.
  6. Dell G5 5000 Gaming PC Ram Replacement: 6 단계, 이미지 1/2 Dell G5 5000 Gaming PC Ram Replacement: 6 단계, 이미지 2/2
    • Line the module up with the slot making sure the stick is the right way and the gap matches on both the slot and the module.
    • Gently place the bottom side of the stick in first followed by the top side.
    • The gap in the ram module is slightly closer to one side of the stick than the other. The side this gap is closer to is the bottom side.
  7. Dell G5 5000 Gaming PC Ram Replacement: 7 단계, 이미지 1/2 Dell G5 5000 Gaming PC Ram Replacement: 7 단계, 이미지 2/2
    • Firmly push down on the stick of ram until you hear an audible click from both sides.
    • As you push the stick down, the latches next to the slot should move back into their original positions.
  8. Dell G5 5000 Gaming PC Ram Replacement: 8 단계, 이미지 1/1
    • If you need to replace multiple sticks of RAM, repeat steps 4 through 7 for your other sticks of ram.
결론
To reassemble your device, follow steps 1 and 2 in reverse order.
Matthew Figueiras
회원 가입일: 09/17/21
157 평판
안내서 1개 작성함
York University, Team F-20, Woodhouse Fall 2021 York University, Team F-20, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 37
전체 시간: 1,645
